Hey there!
I've been using Zorin OS 17.2 for a while and I tried (like always) experiments that I regretted, but I've always managed my self to fix my caused issues, but now I deleted the startup sound from the startup apps. Now when I tried to recover it I've got stuck at the coommand section. Can somebody help me recover the startup sound please ?
Go to the Startup App and click there to add an Entry:
In the opening Window, type to Name and Comment Startup Sound
and in the Line for the Command:
/usr/bin/canberra-gtk-play --id="desktop-login" --description="GNOME Login"
It should look like this:
Oh thanks for fast reply!
Thank you for giving me a solution to that problem. I tried it and it WORKED!
And thank you so much!
