Reduce lowest brightness
Zorin 17 lowest brightness is still too bright for me. It's possible to custom the value of lowest brightness?
Run xrandr --listmonitors and note the moniter name then run xrandr --output DISPLAY_NAME --brightness 1 you can adjust the value of 1 from 0.1 to 1
This will only work if you are using Xorg.
I use version 17.
It will work regardless, just make sure you are using x11
It's also works on Zorin 17 (Wayland).
Screenshot from 2024-09-04 12-14-53
This morning when I checked --listmonitors, it showed "eDP-1". And the method above worked.
But for some reason this afternoon I tried again -- listmonitors no longer displayed eDP-1, but XWAYLAND0. And the method above no longer works.
Meanwhile, since the beginning of OS Zorin 17 I have been using Wayland, there is no Xorg option on the login screen.
Why did it happen?
