Regarding cursor movement while typing or entering in data fields
when I am using my system and typing some paragraph I have seen lot of times my cursors move forward without any key pressed and start typing there and also when trying to login password is also get deleted certain times, If do it with focus, then this issues doesnot come much, if anything possible for this please tell what I can do for it
Do you use a external mouse or touchpad? Do you have a laptop or desktop computer?
Both i use mouse as well as touchpad and use laptop only
Does this also happen when you only use one of them and e.g. disconnect the external mouse (for touchpad only) or disable the touchpad (for mouse only)?
I will try and update you about it but this thing happen randomly not everytime
Are Secure Boot and Fast Boot in BIOS disabled? Does Your system run in Wayland or X11? You can check that with the Terminal Command echo $XDG_SESSION_TYPE
secured boot is disabled and x11 I am using
Okay, let's try something. Go to the Login Screen. Click there on Your Profile so that the Password Field appears. When it is appeared, You should see a Gear Icon in the bottom right Corner. Click on it and choose the Option ''Zorin Desktop'' (that should be the Wayland Option; if You have Zorin installed with Nvidia Drivers, the Option should be ''Zorin Desktop on Wayland'') and then log in.
