I am trying to set up Teamviewer and Rustdesk in Zorin 18. Both are loaded and run fine. When trying to access from another computer, Zoren pops up requesting to allow access. Once approved access is possible. However, I would like to access it unattended. I have looked in settings and searched here and on Google, but cannot find a way to allow for unattended access. Any help would be nice.
Welcome to the forum!
I seem to recall someone else wanting to do this on this forum a while back, but I can't find the thread now. Monday is getting to me.
I believe Teamviewer does support what you're looking for, at least according to their documentation:
Provide unattended remote support
However, I also recall that you may need to go to Settings -> Sharing in order to change remote access to the PC to NOT require confirmation with a password each time it happens. (I'm currently at work right now and can't verify, but this is definitely the case when you're using the built in RDP option and want to login remotely without a login prompt showing up).
