Remote desktop (Portal) open when I copy a password from Bitwarden
Dear all,
I have a very strange issue that started few days ago. Whenever I copy a password from my password manager app Bitwarden, The remote desktop app from system open with a message (please see attached screenshot).
I can't get past it and have to use the browser version of Bitwarden to get to my passwords.
I also randomly get the remote desktop app opening when I copy something.
Very strange, I haven't done anything except applying security updates and installing software updates.
Any ideas?
Is Bitwarden installed as Flatpak? If yes, You could try the .deb Version instead and see if it behanves the same:
Thank you for the message. Yes, I have it installed as Flatpak.
It's a good point, I've tried the Appimage version and it seems to be working fine. So sounds like a Bitwarden Flatpak bug.
Here are some reports:
When the AppImage works and You fine with it, I would say stay on the AppImage for now. Or You could try the .deb Version too to compare. But that is up to You.
Ah thanks, I should have checked this for bug report first.
