Hi! I want to remove Zorin Os pro desktop (gnome) and only keep Zorin Os Pro Lite (xfce). Can someone help me?
I think your best bet is to use the Contact Us
page to request the ZorinGroup to address this question as this is an Installation Support issue.
The Premium Packages can require different commands and handling and using the wrong command could cause you a list of headaches.
Please be detailed in what your desired outcome is: Are you looking to remove any of the included Pro additional Packages?
It is important to note that having both desktops installed does not cause them to conflict with each other, nor does it create a situation where both are running or running on top of it each other. Only the one you log into is running at that time.
Neither of the desktop files take up very much space (It is the additional packages that make up the lions share of space usage).
Hummmmmm .... that sounds familiar ..... déjà vu maybe ????? ......
From my reading of other threads, your installations are like a ZorinOS clothing shop - all the colours and all the sizes. I prefer one size fits all.
Ahhhhhh ..... but 'variety is the spice of life' ......
