hi guys, i need your help with something. I have zorin installed on my gaming laptop (16 inch display), and i recently got a 24,5inch monitor. While i was only using my laptop screen i had a 200 percent scale, but on the monitor i bought only 100 precent scale looks good. However, I cant seem to have an option to set the scale only to one of the displays, if i set 200 percent to the small screen, the bigger screen also scales to 200 percent. Why can't i set them individually? How to fix that? i appreciate any help, i'm pretty new to this os and to linux in general. Thanks!!
Have you tried this using Fractional Scaling rather than integer scaling?
When You go to Settings>Displays, You have in the top right Corner the Options for ''Join'' and ''Mirror''. Choose Join and You can set up the Display Settings for each Monitor individually.
yeah i tried it but it keeps applying to every display
thanks tho
it worked! thanks a lot
