@Aravisian Now I have this drivers
any advises for the brightness problem
You appear to be using the 470 (Proprietary - tested) driver instead of the 340 driver described in the posts above.
I recommend against the 470 (Proprietary - tested) in any case as it is buggy. The 470 (Proprietary) driver is not buggy.
ok I'll try to switch to
now or
The 340 driver as we outlined above.
You must follow the link that I posted in this thread here:
Crosslink:
Please open terminal and run:
sudo add-apt-repository ppa:kelebek333/nvidia-legacy
sudo apt update && sudo apt install nvidia-graphics-drivers-340
The repository lists them:
nvidia-graphics-drivers-340 (340.108-4ppajammy8) jammy; urgency=medium
The .deb package:
https://launchpad.net/~kelebek333/+archive/ubuntu/nvidia-legacy/+files/nvidia-331_340.108-4ppajammy8_amd64.deb
You might try running it using Gdebi to install with all dependencies
The full list (under Jammy)
Once I installed this using the
I loat my sys and proc files from the system and i can't open the os i got this
Your other option is to use the 470 driver and understand that the graphics may not work properly...
I can only recommend upgrading the graphics card at this point or using an older release that is compatible with the existing hardware.
What are the chances that this is caused by a hybrid GPU driver setup?
What application is it that causes this? A specific one, or a few of a certain type, etc.
Consider...Some applications do it but others don't:
that happened twice after I install nvidia 340 drivers
