Second screen detected but is not sending signal unless mirrored
Hey guys, so I've been using the latest os and I can't get the second monitor I'm trying to use to accept signal unless I mirror the laptop's main screen. It's detected and I have it in "join", I've tried doing super+p and it still will only do mirror, and won't even run just on the extended screen if I select it. I've tried logging in with wayland. Did the Software and Update for the nvidia driver for the 965m. Running on an asus rog g752v.
just solved my own problem via brute force. Forced the nvidia driver into using a refresh rate that wasn't listed.
You can also test if it helps to switch to Xorg. Logout and at login click on your username, then a cog wheal appears at the bottom right corner. There you can switch between Xorg and Wayland.
Perhaps your older hardware is better supported by Xorg.
