Then in your terminal window, either use ctl+shift+v to paste or use Mouse Right click - context menu and select paste.
Once the above is pasted in, tap ctrl+o
That is the letter o, not a zero.
Then hit the enter key to save as current configuration.
Tap ctrl+x to eXit the editor.
Then run:
I just 'did the thing' & it seems to have worked...
Haven't restarted my computer but all seems fine...
I noticed swap mentioned in 'swapon --show' results - this makes me think that SSD swap IS being used(automatically)with this setup - & if that is true, I understand why I was advised/made to disable(¨killed" is what I saw after the fact)my swap before setting this up...
Question on this. I did see this app, i did not think it will have a real world improvement. I haven't used it.
With my system running no swap, yes no swap, and still going well. I have my root (/) directory on my NVme and the /home directory on a spinning drive. Seeing storage is so very cheap in this day and age.
Will this app zRAM, make a real world difference? For example loading times, performance?
It can help if your RAM is insufficient for the operating system and usage. But if your system is running fine - using this will not create any difference you would notice.
That is not its purpose - and there is nothing in how it is implemented that would create a performance boost in normal use.
Sorry it took a few days to reply. Here is what it shows when booted into Wayland.
zramctl
NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0 lz4 4G 288K 34K 368K [SWAP]
name@comp-name:~$ swapon --show
NAME TYPE SIZE USED PRIO
/dev/nvme0n1p7 partition 5.6G 0B -1
/dev/zram0 partition 4G 284K 100
I changed my logon name and computer name other than that that is verbatim.
I'll reboot into x11 and update this post or add a second one.
EDIT:
X11
zramctl
/dev/zram0 lz4 4G 4K 69B 20K [SWAP]
/dev/zram0 partition 4G 0B 100
It always shows zero for both swap and zram on x11 and x11 will slow way down after running for a day or two, but Wayland doesn't , but has issues with NVIDIA, services sometimes.
I should have added, that I used "ram /2 4096" and "lz4" vs what you posted, but I did mine before I saw your right-up.
I am running a laptop with a 17.3 in monitor, a 10870H, 32 gigs of 3200/c22 RAM @2933, RTX 3060 6 gigs dedicated on open driver 595.99.02, and drives are both NVMe: WD_BLACK SN770 2TB and PNY CS3030 1TB SSD, kernel 7.0.0-38-generic.
A few points:
You are best to not use zRAM and Swap at the same time.
Use one or use the other.
The second is; these actions are completely independent of the Desktop PRotocol.
So, whether you are on Wayland or X11 will make no difference in this, at all.
And this shows in your output; You are using 0 of the swap.
A slowdown observable on GNome when using X11 makes sense, and has nothing to do with RAM, really. It has to do with Gnome, and that Gnome is cutting X11 and pushing for Wayland only. Gnome is no longer optimized on X11.
Thank you for the helpful information.
I didn't know if I should have gotten rid of the swap or not so I just dropped it's priority way down. I have a long way to go in learning the ins and outs of Linux. I used to spend days gutting Windows and customizing it ridding it of MS's junk, but I had to just give up on their AI slop. After years of playing with different distros, I finally decided to move over to Linux as my primary OS. That's what I mean by I have a long way to go and a lot to learn.
apply optimizations for zswap and zram
zram: use a singleton compression context for recompression
zram: split zcomp into separate R/W streams
zram: reset writeback state in zram_reset_device()
zram: zstd: do not use kvzalloc() for zstd allocations
zram: lz4hc: use LZ4_decompress_safe_usingDict()
zram: lz4: use LZ4_decompress_safe_usingDict()
zram: lz4hc: pre-initialize dictionary stream in setup_params
zram: zstd: do not allocate empty C/D-dictionaries
zram: remove debugfs entry on init failure
zram: prefix backends printk-s
zram: convert to SG-list zsmalloc object read API
zram: add pr_fmt to backend files
zram: do not release zstd global params from error paths
mm: zswap: use stack requests for synchronous decompression
mm: zswap: use separate compression and decompression requests
