Setting wired network settings does not stick
I have my wired network settings set to manual. I have changed the DNS settings and clicked [Apply]. However, the new settings are not changing for the system. On the 'Details' dialog for the 'Wired' connection, it is still showing the same DNS servers.
What might be wrong?
Welcome! :sunglasses:
Have you rebooted after saving the changes? Lots of network changes require a bounce, or reboot, for the changes to take effect.
Have you considered changing your DNS settings in the router config?
