Shortcut is not working in Zorin's latest
Screencast from 2024-07-28 14-07-51
As you can see on this gif . I am not able to use my shortcut ctrl + . in my ide or vscode . how to off this ?
Does this stackoverflow thread shed any light on the issue?:
No, I checked all shortcuts . Everything is ok. but still not working
This shortcut is being used for something else. If you cannot change this shortcut in the application that are opening, the simplest solution is to define another shortcut in Vscode.
I had the same problem with Ctrl + Shift + P which opens the command palette. Doesn't work on Zorin. I tried several solutions that didn't work, until I simply decided to use F1.
