Shutdown on Zorin 16.1 Pro was always ok (3 or 4 seconds), but recently has an issue.
This message shows up and hangs the shutdown.
Somebody know the cause and how to fix it?
Can you check the logs?
journalctl -b-1 | grep systemd
Your error mentions a tainted kernel. This often means a conflict with installed Proprietary AMD or Nvidia graphics.
You might just reinstall your graphics drivers and see if that resolves the issue...
All working ok here now.
Timeshift was doing this.
It was disabled and all working ok.
