Hi everyone,
this is a simple guide for new users who want to install Zorin OS on a gaming PC or gaming laptop, especially systems with NVIDIA graphics cards such as GTX or RTX cards.
Many new users think the installer is broken when the screen freezes, goes black, shows graphical problems, or crashes during installation. Sometimes the problem is not the USB stick or Zorin OS itself, but the graphics mode used during the first boot.
Gaming PCs often have stronger hardware than normal office computers, and NVIDIA graphics cards sometimes need the correct driver option from the beginning.
Before installing, I would recommend these basic steps:
First, back up your important files. Never start a new installation without a backup.
Second, create the Zorin OS USB installer properly. If one tool does not work, try another USB stick or another tool, but also check that the downloaded ISO is not corrupted.
Third, if Windows is still installed, disable Fast Startup in Windows. This is important because Windows can leave drives in a locked or half-hibernated state.
Fourth, enter BIOS or UEFI and check a few basic settings. Use UEFI mode if possible. Make sure Fast Boot is disabled. If you have problems with NVIDIA drivers, Secure Boot may also need to be disabled.
When you boot from the Zorin OS USB stick, look carefully at the boot menu.
If your computer has a modern NVIDIA graphics card, choose:
“Try or Install Zorin OS (modern NVIDIA drivers)”
This option is important for many newer NVIDIA cards because it starts the installer with the proper NVIDIA driver support.
If the normal option gives you a black screen, graphical crash, frozen installer, or strange display output, do not panic. Restart and try the NVIDIA driver option or, if available on your boot menu, a safe graphics option.
During installation, when you reach the “Updates and other software” step, enable the option:
“Install third-party software for graphics and Wi-Fi hardware and additional media formats”
This helps the installer include important drivers and compatibility software.
If possible, connect the computer to the internet during installation. Ethernet cable is best if Wi-Fi is not working yet.
After installation, restart into Zorin OS.
If the system boots but graphics still do not feel right, open:
Zorin Menu → System Tools → Software Updater → Settings → Additional Drivers
Then choose the recommended standard NVIDIA proprietary driver, not a server driver, apply the change, and restart.
If the NVIDIA driver still does not activate properly, try logging in with:
“Zorin Desktop on Xorg”
instead of the default session. Also check again whether Secure Boot is disabled, because Secure Boot can sometimes stop NVIDIA drivers from loading correctly.
For AMD and Intel graphics, this is usually easier because the open-source drivers are normally already included in the Linux kernel and Mesa stack. But for NVIDIA gaming systems, driver choice is often the main point.
So the short version for gaming PCs is:
Back up your data.
Disable Windows Fast Startup.
Disable Fast Boot in BIOS/UEFI.
Use UEFI mode.
For modern NVIDIA cards, boot with the Zorin OS NVIDIA driver option.
Enable third-party software during installation.
Install or confirm the recommended NVIDIA driver after the first boot.
If needed, use Xorg and check Secure Boot.
This can save a lot of frustration for new users, especially people coming from Windows who are installing Linux on gaming hardware for the first time.
Best regards,
Daniel
