Small Print In Game Play
It seems that some games run very small print when describing an item like with the 'Ground Cloth' example below n my theHunter Classic game ..... Steam even mentions it with a way I assume to over come this problem ..... however I'm not able to figure out how to use it .... it mentions that for PC you combine ...... 'steam + MB' to make the print larger ......
Usually the + on my laptop keyboard will increase the size of the screen but not in the game ....
What do you folks suggest ????? .... yes I have a magnifying glass but that is kinda a PITA to use each time I need to view the small print ....
