Does coustimization on my zorin os does it makes my computer slow or not
To answer; you would first need to define what you mean by Customization. If you mean running system themes, icons, setting up preferences; Then no, this will not slow down Zorin OS.
If you mean customization software and how it interacts- then it is possible to slow the system down.
