[Solved] Deja Dup problem
Hi again. I have Deja Dup set to back up to Google Drive/OldMesh DEjaDup and it backs up with no problem and I can see the backups in this Folder. However, Restore claims the folder is empty! Any ideas?
Using Brave A.I. search engine came back with this:
Deja Dup Google Drive Restore Issue
When using Déjà Dup to restore files from Google Drive, users have reported issues where the application does not ask for the Google account to choose from and instead states that there are no backups to restore. This problem can occur if Déjà Dup is using the wrong Google account or if the account access has not been correctly set up. To resolve this, users have suggested removing the Google Drive account from the "Online Accounts" settings, restarting Déjà Dup, and then granting access again. Additionally, some users have found that mounting the Google Drive account in Nautilus and using the "local folder" option in Déjà Dup can be a workaround.
Just to add I have never used Deja Dup.
I deleted everything from Google Drive, uninstalled and reinstalled DD, and started from scratch and now it works
