is there a way to make the sound setting also have a way to change the output device on here, it is very annoying to go through settings all over just to change the output. Like i want it to work like wired settings, when i click wired on this menu it gives me a option to change the connection type.
Sound Input Output Device Chooser extension?
There's an extension for that on gnome extention page.
To help the OP and to clarify, are you both referring to page in Zorin Software Store?
Tested here with Zorin 16.2 - it works like wanted: https://extensions.gnome.org/extension/906/sound-output-device-chooser/
thank you all, this works like i wanted
I have moved this post from Customisation to General Help.
Question now is which post should be marked as "Solution". Maybe @codseus you can choose which finally helped you most and mark it as the Solution. Just click on the "..." under the chosen post and pick the Solution option.
i'm sorry i usually do that but i forgot this time.
Hi Folks Hi Folks
I have a sound issue that I have tried to suggested solutions with no luck.
At booting my sound does not work, going to the settings I have four options.
1/ Speakers-USB audio device (Zorin defaults to this each time) = No sound
2/ Digital output (S/PDIF) = No sound
3/ Digital output (S/PDIF) Built in audio device = No sound
4/ HDMI/DisplayPort2-GK208 HDMI/DP Audio Cpntroller works perfect.
Is it possible to disable three options leaving the option that works, avoiding adjustment each time I boot.
I need the option 4 as the hardware works with the Mac set up which I can choose at boot.
Thanks in advance
maybe this can help you : Ubuntu – How to set a default audio output device in Ubuntu 18.04 – Unix Server Solutions
