i was trying installing wo mic app in my pc, in it's instruction to work execute that command sudo modprobe snd-aloop, after i did that , my pc can't get sound.How i can get it again?
What happens if you
sudo modprobe -r snd-aloop
no sound, i didn't know what that command did
Modprobe - Module prober. It probes the acting modules for the kernel - essentially, turning drivers on or off.
sudo modprobe (module-name)
will enable it, and sudo modprobe -r (module-name)
or sudo modprobe --remove (module-name)
will disable it.
Did you reboot?
no, i didn't. I did reboot, and it's working. thank u very much
