Spotify not loading in Zorin Os 18 Core
The Xfdashboard reads like some kind of activity overview. Thank you for the interesting tipp!
I'll try it in the next days.
I'm not quite sure how it can be installed.
I found
sudo apt install xfdashboard xfdashboard-plugins on wiki.ubuntuusers.de, but there is not said for which ubuntu version this command is.
Here are a few files but no .deb:
Which one is the right one?
Is also this command needed to install all dependencies
apt-get install xfce4-dev-tools build-essential glib2.0 libglib2.0-dev
    xorg-dev libwnck-3-dev libclutter-1.0-dev libgarcon-1-0-dev
    libxfconf-0-dev libxfce4util-dev libxfce4ui-2-dev libxcomposite-dev
    libxdamage-dev libxinerama-dev
Is the zorinappgridlite plugin already installed? I haven't found a app with a name like grid or activities.
I found the .deb file to download from here:
Is the
xfce4-zorinappgridlite-plugin_1.0.0-1_amd64.deb the right one for Zorin lite 17?
This is just a plugin for the zorin-appgrid-lite package in AUR.
This is not an Official Zorin OS package - it is a user created package for Arch Distros that emulates some of the Zorin OS look and feel.
I stand corrected:
This is present in Zorin OS 17 - I am probably finding so little about it because Zorin OS 18 Lite has not been released yet. I punch myself in the face.
On Zorin OS 17:
Appgrid-lite
https://launchpad.net/~zorinos/+archive/ubuntu/stable/+files/zorin-appgrid-lite_1.0.2-1_amd64.deb
Plugin:
https://launchpad.net/~zorinos/+archive/ubuntu/stable/+files/xfce4-zorinappgridlite-plugin_1.0.0-1_amd64.deb
I cannot find much about either of these packages. They may work fine, but without knowing what they depend on - I cannot recommend them without testing them.
It is in the Noble repos, accessible on Zorin OS 18:
apt search xfdashboard        ─╯
Sorting... Done
Full Text Search... Done
libxfdashboard-dev/noble 1.0.0-0ubuntu3 amd64
  GNOME shell like dashboard for Xfce - development files
libxfdashboard0/noble 1.0.0-0ubuntu3 amd64
  GNOME shell like dashboard for Xfce - shared library
xfdashboard/noble 1.0.0-0ubuntu3 amd64
xfdashboard-plugins/noble 1.0.0-0ubuntu3 amd64
  GNOME shell like dashboard for Xfce - plugins
Can you check for 17 with
I installed the xfce4-zorinappgridlite-plugin via synaptic. Synaptic also installed zorin-appgrid-lite.
Then I added the plugin to the taskbar. It is shown as 9 dots icon like in Zorin core. I hadn´t known that something like this exists for Zorin lite.
The icons for the apps shown here depend on your chosen icon theme.
That is the xfdashboard, I also installed it with synaptic.
@Aravisian Thank you very much for your help and the ideas.
It is very difficult to hit the hot corner to open the xfdashboard. Is there a way to enlarge this one pixel point?
I had no idea about zorin-appgrid-lite, as well.
I did know about xfdashboard - but it was not something I enjoyed. I had it installed for a while but it seems to add complexity, needlessly.
It does not have hot corner by default, so what you are hitting is a 1x1 px square, lol... I imagine that is tricky alright.
Try
sudo apt install xfce4-hotcorner-plugin
From its properties, you should be able to set the area.
Thx for all your research here. How did you attach the plugin to the taskbar after installing it in Synaptic?
Right-click on your panel, then select panel > add new item and in the list search for xfce4-zorinappgridlite-plugin, click on it and and then on add.
Afterwards you can move it on the panel to another position by rightclicking on the icon and select "move" to drag and drop it.
That is great thanks. I really appreciate your help and it sounds like we all learned something new in the process.
