So I am a new users that has been on Windows for a very long time because I could not find a distro that I really liked, until I just discovered Zorin. So far I like it pretty well with some exceptions and am making it my daily driver at home.
I would like to be able to pin applications in the initial click of the start menu for quick and easy access. However it appears that the current menu does not support this function. I did however install the ARC menu which has much more options and functionality which I prefer, however now I cannot seem to get rid of the Zorin menu. Is there an easy way of doing this? From what I could find on the web it seems pretty difficult.
Using the Extension Manager in the Settings, you should be able to disable the Zorin Menu extension.
EDIT: @Forpli, Jinx.
Alright... you get on that side. I will get on this side and on the count of three, we each pull and see who gets to keep Obsidian.
Well that was easy. LOL However @Aravisian, you did miss a step. You have to go to "Apps" in Settings to go to Extension manager. So I will give you an A-.
