Step "Device for boot loader installation"
Nothing appears inside the window that should show the partitions. It's a huge white square. And bellow the window, the "already selected" option is "dev/sda. And when I press "Continue", this is the message:
File "/usr/lib/ubiquity/plugins/ubi-partman.py", line 1524, in on_partition_list_new_activate
self.partman_dialog(devpart, partition)
File "/usr/lib/ubiquity/ubiquity/plugin.py", line 48, in wrapper
return target(self, *args, **kwargs)
File "/usr/lib/ubiquity/plugins/ubi-partman.py", line 1187, in partman_dialog
if create and partition['parted']['type'] == 'pri/log':
TypeError: 'NoneType' object is not subscriptable
Someone help, please?
Are you wiping the disk in order to install?
Or are you booting alongside an existing OS?
Are Secure Boot and Fast Boot in BIOS disabled? Could You post a Screenshot from the Install Step?
