Hi, i recently did sudo apt upgrade, in zorin os.
before that i had 106.8 gb of storage avaiable but now only 105 gb
i did the commands like
sudo apt clean
sudo apt-get autoremove
and commands like that and then rebooted. but still no freeing up in storage. is there any solution for this or this is normal.
It would depend on what packages were upgraded. If the upgrade called for packages that are larger than the older versions, and there were a significant number of packages upgraded, this wouldn't be at all unusual. Apt clean and apt auto-remove can't free space if the space is legitimately used, after all.
