I'm getting this weird glitch on all GTK windows on mouse hover. It only gets fixed once I move the window. Why is this happening and what can I do to fix it?
Is this on Core or Lite? Your profile states you have both.
What graphic card?
What mouse?
That's not a glitch but a Zorin OS feature , cloak engaged
Please post the output from lspci
, you can write this up in the terminal.
It wasn't happening before, I installed a few extensions and the bug started appearing. I have since then removed the extensions but the bug persists.
I'm running an Nvidia GTX1650, Ryzen 5 3rd gen 6 cores and 24Gigs of RAM.
Which extensions and have you installed /removed anything else?
These are the ones I'm currently using. I removed those that were installed before this bug started appearing
I would suggest using Gnome Tweak Tool to disable all extensions, then test if the bug is still present after logging in.
If it is present, we can rule out the extensions as a cause.
If it is not present, you can enable and test extensions one by one until narrowing down which is the problem.
Okay, looks like it's being caused by blur-my-shell. It was working just fine for months, I guess I'll try to reinstall it and see if it works.
Thanks for the help
