Stuck on installation screen
I’ve been stuck at the very first screen where it makes you pick a language and asks you if you want to try or install zorin. I clicked on the install button and it got stuck and has been for about 20 minutes. I tried quitting rhe page but nothing happens if I do. I also cant open my boot screen on my pc and it puts me back to the screen, still stuck whenever I restart my pc. Any ideas on how to fix this? Thanks.
Hi Qwip, and welcome. Is this a Desktop or Notebook computer? Are you trying to dual-boot with Windows or is Zorin the only OS you are wanting to install?
hi, I was able to fix the problem by re booting it from my flash drive. Thanks for your help though!
If now fixed, can you mark your last post as :white_check_mark: Solution.
