Stuck on login screen after hibernation
when i suspend the system and it locks it, i had this problem:
first login screen works normally, but when i unlock it appears another login screen and at this one i can't type, my cursor works normally, my keyboard also works cause if i press the caps key the system recognize it showing the "caps lock warning", the only way that i knew to get out of this screen was to cut the energy by holding the power button.
I already disabled the lock screen so this would not happen again, but in that way my system is open to anyone that just open the shell.
I would like to know if there is a way to fix that bug, i tried to reinstal the lightdm by sudo command but dosen't fix.
System: zorin os lite free
Processor: Intel(R) Celeron(R) CPU N3350 @ 1.10GHz
RAM: 4GB DDR4
DISK: 64GB eMMC
If this is a notebook computer, try disabling lid switch handling:
xfconf-query -c xfce4-power-manager -p /xfce4-power-manager/logind-handle-lid-switch -s false
