after a long time i have switched to fedora 35, I had put a lot of thought into it and tried it, I liked it and then replaced zorin with it, My biggest concern was that the ui wont be as good but i like it especially after some tweaking, Any thoughts?
P.s i would be very active on the zorin community it is one of the best ones i have ever been to
Making personal adjustments usually has this outcome.
Fedora is a solid and stable well supported distro.
You are free to stay. Many users use other O.S.'s.
oh i thought it would be awkward for me to stay
thank youbtw
and i will definitely be back when zorin core 17 comes out
I am also using Fedora 35 and KDE Neon along with Zorin 16 XFCE
And have you tried the Blur My Shell extension?
no i want to but i think its too buggy so i try to stay away from blur my shell
Oh yes I did, here it is.
When opening folders such as 'Utilities' folder, the blur doesn't work properly, other than that there are no bugs.
You can also share some specifications of your computer, so that I can check if Blur my shell can work on it or not.
mine is i3-8130u
8gb ram
1tb hdd
intel uhd graphics
PS i have installed it and it works fine except that bug with folders that you mentioned
btw how much ram does fedora use on your pc. It uses about 2.5- 3.5 gigs on mine on idle is that normal
thats how it looks on my laptop
Currently my parents are having my laptop, so I can't tell.
ok but please tell me how much ram it uses after you get your laptop
what are the specs of ur laptop
Khnome
6 January 2022 15:35
18
For me it uses 1.2GB maximum on idle. Maybe you didn't reboot for a long time?
i just installed it today
Khnome
6 January 2022 15:40
20
I don't like fedora 'cause dnf/yum and packagekitd are using a lot of RAM, so my computer is unusable during updates or than I'm installing software and I have only 4gb of RAM
it might be because of the 4gb ram that you are not facing the issue, ive heard that linux dynamically uses ram according to demand and stuff
