System freeze while moving around app menuMy system locks up completly while moving
my system completely locks up while moving around the apps menu and i have to do a hard reboot. I think that's why nothing is mentioned in log files.
Where do I start looking for what caused this?
Thanks for your help.
If this is a regular thing, like it's always happening when you do certain actions, I'd recommend checking the ISO file that you used to install Zorin OS and consider re-installing it. It's possible something has gone wrong during the installation.
Thank You. I upgraded to pro from the not pro system. I'll reinstall if it continues.
What Apps Menu You move around?
