I’m trying Zorin in live boot mode. When I connect an eGPU, the system either freezes or the mouse is functional, but the system is unresponsive. Either way, I’m forced to restart my PC (force shutdown) if this happens. My eGPU specs are below:
eGPU case: Razer Core X
GPU in eGPU: AMD Radeon RX 6600
GPU when eGPU is not connected: (Mesa) Intel UHD Graphics
I don't get this. This is way too confusing. The only thing I got was to run a live boot session with safe graphics, however, I feel like that removes some animations; I'm all for animations. It's what makes an OS immersive for me. And plus it takes a long time to shut down.
I will trying researching on internet and trying to find something to help you.
Please only put command inxi -0 where i can check peripherals software. In theory did you changed something in laptop some parts example ram,ssd or somethinf else? If your battery is old on motherboard it could be also that problem.
So it is possible Ram eating more power then your laptop is warmer and it could be with some freezing because power consumption?
I have that issue when my gpu card needed more Watt from power supply and my pc freeze,crashed and restarting.
