System hard freezing intermittently (on network load?)
I installed Zorin OS on a family member's computer, and they have been experiencing persistent intermittent crashes. The system will completely lock up and require a hard restart. The OS install is completely stock and is the only OS on the drive.
I followed the steps on this official help page with no results, which should rule out the possibility of faulty hardware. I also checked the BIOS and drivers are up to date and tested with all non-essential peripherals disconnected.
Checking the logs, there are no errors or warnings whatsoever leading up to the freeze. Initially suspecting this could be related to power states, I edited the grub.cfg and disabled VT-x in the BIOS with no results.
The freezing appears to occur when a heavy network connection is attempted, such as loading a heavy web page, opening a large document, or connecting to a Zoom video call.
Here are the system specs for reference:
OS: Zorin OS 18.1 Core
CPU: Intel Pentium G4600
RAM: Kingston HyperX 16GB 2666mhz
Mobo: Asrock H110M-STX (BIOS v8.10)
Hello and welcome,
Did you try to disable secure boot in your BIOS ?
Also are you under wayland or X11, check like this
echo $XDG_SESSION_TYPE
If it's Wayland try it with switching to X11/Xorg. To do that, go to the login screen. Click there on your profile so that the password field appears. When it is appeared, You should see a gear Icon in the bottom right corner. Click on it and choose the option ''Zorin Desktop'' and then log in and test it.
Are Secure Boot and Fast Boot in BIOS disabled?
