System point
Hi everyone
I'm using the windows
And moving to zorin os
Help me
How to create system restore point in zorin os.?
cant remember if it's preinstalled with zorin , but what you want is timeshift
@aaoaa Hello and welcome!
No Timeshift isn't pre-installed but it is easily installed from the software store.
Timeshift is classed by most users as essential, however, it is not the same as a restore point in windows. It backs up your system and you can fully restore it from a Snapshot, but you need another app for YOUR FILES, photos, music, etc., etc..
Déjà Dup does come pre-installed in Zorin 17.1 Core, and you should set it up to protect everything. It is very simple to use. I don't know if it is installed in Zorin Lite but you will find it in the software store.
