System requirement for my laptop
Hello Zorin Community,
I am currently using Linux Mint (Cinnamon) and I am thinking of using Zorin OS but i am not sure whether it will work stable or not.
My Laptop's Hardware details:-
inspiron 3593 i3 gen 10 with RAM 8GB (I can upgrade to 16GB) , SSD 256GB + HDD 1TB.
I don't do any type of Gaming in my Laptop but do programming like running k8's clusters , dockers etc.
Even if i want to choose Zorin Core would be there any problem while using it?
When Linux mint cinnamon is running well you can use Zorin core without problems.
Zorin core with gnome is more modern than Zorin lite with xfce but when you want to customize much on your system and want a better performance Zorin lite is more flexible and faster.
I must qualify this statement... They are both equally modern and maintained, in fact, the Zorin OS Lite XFCE version is higher than what comes with the base.
You may mean that Gnome looks more modern... Which is... a matter of subjective opinion.
Some people say this about Zorin lite especially when they have not yet taken a closer look and are only judging by first impressions. You can adapt it easily so that it looks and behaves like you want (almost...).
This is not my opinion. I am a fan of xfce because of less restrictions and more freedom.
thanks for the reply,
I will surely tryout Zorin OS CORE/Lite
Vanilla Gnome and Vanilla XFCE... or Vanilla Cinnamon, for that matter, all look "dated" to most users. That is why customization is important for the end user.
Summary
Many people say Gnome is polished. Why? Because other people did. Article authors call it polished.
Is it polished?
Absolutely not.
The widgets overlap and blend into each other. The Headerbar (titlebar) varies in size, depending on not only the application, but the configuration of what buttons you have enabled on it.
There is header-right, headerbar and header-left, which can mismatch each other.
What else?
Minimize/maximize/close buttons are often inconsistently placed.
No Unified Padding or Margin Rules. Spacing between elements (sidebar and panes) varies across GNOME apps and GTK apps.
Opening GNOME Settings, System Menu and App Menu will Overlap on Small Screens; Elements will overlap or truncate on fractional-scaled displays.
Top Bar icons collide or get hidden when using extensions or fractional scaling; icons can get cut off or shift awkwardly.
Buttons, toggles, and labels often blend into the background. They take "flat" to another level and call it modern.
GNOME Core vs Libadwaita vs GTK3: Applications using GTK3 look and behave differently than those using GTK4 + Libadwaita. Theme integration is broken between them.
GNOME deliberately resists user theming (LibAdwaita). This leads to GNOME apps looking different from non-GNOME GTK apps (e.g., GIMP, Inkscape, etc.), even on the same desktop.
No support for GTK custom Titlebars in Non-GNOME Apps makes apps using standard titlebars stick out like a sore thumb. Completely mismatched.
Inconsistent Keyboard Shortcuts: Shortcuts vary across GNOME apps; Ctrl+Q may quit one app, while another requires Ctrl+W or Esc.
Many functions (e.g., middle-click to close a tab) are undocumented or inconsistently implemented. This makes discoverability a nightmare.
"Polished" Shouldn’t Depend on User Fixes. GNOME is often described as polished after extensions are added (Dash to Dock, AppIndicator, TopIconsFix, etc.). A desktop environment requiring several third-party patches to feel usable isn’t inherently polished. Zorin OS 16 and 17 have done a remarkable job of makeing Gnome usable and well constructed and yet, I still find it awkward and clunky.
There’s no way to disable or tweak inconsistent or laggy animations natively. Some apps animate transitions (like GNOME Weather), while others snap abruptly between views, with no consistency.
Not all GNOME apps honor system-wide dark mode settings.
High Contrast and Accessibility Themes Are Neglected. Some apps become barely usable with accessibility themes—text blends into the background or icons disappear.
No per-monitor DPI settings; font scaling is global and limited in granularity.
That wouldn't be a bad Idea in my Opinion. With the 8GB it could be enough, yes. But depending what Graphics You (dedicated or iGPU), it could be good to have a bit more RAM.
You could create a Dual-Boot System with Mint and Zorin. So, You would have a direct Comparison on Your Hardware. If You want it a bit more Ressource-friendly, Lite would be the better Choice in my Opinion.
