System requirement
I would like to purchase Zorin, but I am not 100% sure it will work on my Lenovo Yoga. Everything checks out with what I read on your site except for the CPU. I am not savvy with this so will Zorin work with Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz (1.80 GHz)? It isn't a dual core or does it need to be 100% of what you are showing the need to be, word for word?
You can create a Zorin usb boot stick (the same procedure which you need to install Zorin) and boot in "Try Zorin mode" to test if everything works. The CPU should be no problem.
If I were you, I would first install the core version, and if everything works well, then upgrade to the pro version. Some users were disappointed when they bought the Pro version but haven't tried the Core version before to test if they like the system at all and to see if everything works fine (WLAN, Printer, Audio, camera....).
You mean these Requirements?
You can read there ''Minimum hardware specifications''. So what You find there is the Minimum. Your's is obviously stronger. So, this shouldn't be a Problem.
An easy Way to check out the System, @Forpli has already described.
