bolig
December 20, 2025, 12:39pm
1
just installed zorin on a laptop. works fine. in the "software" app it tells me there re updates. specifically to "thinkpad P53/P73 system update"
but when i try updating i get the error
/boot/efi does not have sufficient space, required 71.1 MB, got 49.2 MB
during installation i did not choose the boot efi size.
Is this a dual boot setup?
Also share a screenshot of Disks app selecting your drive.
Please install Gparted with the Command sudo apt install gparted and then open it and make a Screenshot of the Partitions from the Drive where Zorin is installed.
bolig
December 20, 2025, 6:34pm
4
thanks. i solved it. the problem was due to multi-boot. so microsoft folders was taking up space.
i solved it
opening a filebrowser to /boot/efi/EFI
moved the microsoft folder to the desktop
installed the upgrade using the "softwares"
moved the microsoft folder back
i deleted a lot of language folders inside the microsoft folder i never need (polish, japanese, russian, ...)
i think this was better than fidling with gparted since moving the windows partition can cause problems if i ever want to boot to windows again
system
Closed
March 20, 2026, 6:34pm
5
