The taskbar is filled color silver / white and does not transparent,
First install it is work and transparent the taksbar
Hello and welcome to the forum. Right click on the panel and go to panel > panel preferences. Then click on appearance in the panel preferences window. In background, select style as solid color. Then click on color and select the '+' option under custom. Choose a color and at the bottom you can move the pointer to the left side to increase the transparency of the color and click on select.
I am moving this thread from tutorials to general help.
This is cannot work...
And taskbar was random damagas
What kind of damages? Can you send a picture?
Please also ensure in Window Manager Tweaks
> Compositor > "Enable Display Compositing" is checked ON.
