Temporary stuck in memory
I am trying to get Freefilesync(FFS) to work. FFS is a directory synchronization/back-up tool working. I used it to back up changes to a NAS.
FFS creates these temporary files in the target folder, which are supposed to go away after it is done. But today there is one which won't go away. I found out when I tried to delete a folder on NAS to make a fresh copy, and the tmp file will not be deleted:
I also wasn't able to find the process that was holding it open:
This one file is holding up the entire works.
The FFS was initially installed from a flatpak but the upgrade was installed by executing a downloaded .RUN file. The .RUN file did not uninstall the old version. So I uninstalled the old version using the SOFTWARE app and that may have caused this problem. According to LLM advice I should try to uninstall the app that come with a .RUN using a script provided by the maker which I found in the form of an .SH file. But no:
Also there is no "allow launching" in the file context menu, I suppose because of where it sits.
I'd appreciate any hints to help clear this file out.
Try with sudo
Did You tried to delete the File manually in Terminal? Click on the 3 Dots at the side and choose the Option ''Open in Terminal:
When the Terminal opens type sudo rm instmsiw-1482.ffs_tmp to remove it. You have to tyoe in Your Password.
