Just had a search using Brave A.I.:
Display Port Blue Screen Ubuntu 22.04
When encountering a blue screen with DisplayPort on Ubuntu 22.04 in live mode, it might be due to issues with the NVIDIA drivers or incorrect display configurations. One approach is to try reinstalling the NVIDIA driver, as suggested in the context for similar login issues.
Additionally, you can attempt to reset the display manager by running:
sudo systemctl restart gdm
Another solution involves checking if the display settings have been corrupted or modified incorrectly. You can remove the xorg.conf
file, which may resolve display issues on boot.
If the problem persists, consider switching to the Nouveau drivers, as they might work better than the proprietary NVIDIA drivers in certain scenarios.
To switch to Nouveau drivers, follow these steps:
- Open "Software & Updates."
- Go to the "Additional Drivers" tab.
- Select the Nouveau driver.
- Apply the changes and reboot your system.
If the issue still isn't resolved, ensure that your system is configured correctly for dual monitors. Sometimes, incorrect configurations can lead to display problems.
For remote desktop connections specifically, there are known issues with the xrdp package in Ubuntu 18.04.3, but this information might not directly apply to Ubuntu 22.04. However, it's worth noting that full-screen mode in all monitors can cause issues with remote desktop connections, leading to a blue screen after login.
If none of these solutions work, you might need to seek further assistance from the Ubuntu community or forums, providing detailed information about your hardware and the exact error messages you encounter.
Black Screen Or Login Issues (Ubuntu 22.04) - System76 Support
](Black Screen Or Login Issues (Ubuntu 22.04) - System76 Support)[
askubuntu.com
18.04 - Remote Desktop -- blue screen after login - Ask Ubuntu
](https://askubuntu.com/questions/1166568/remote-desktop-blue-screen-after-login)[
linux.org
[Solved] Ubuntu 22.04 displayport cutting in and out | Linux.org
](https://www.linux.org/threads/solved-ubuntu-22-04-displayport-cutting-in-and-out.41090/)[
askubuntu.com
external monitor - Ubuntu 22.04 : No display signal from device - Ask Ubuntu
](https://askubuntu.com/questions/1412695/ubuntu-22-04-no-display-signal-from-device)
What this jogged my memory with is the fact that Zorin now uses the Wayland Compositor by default which has issues with nvidia graphics.
What happens if you logout of the live system, enter liveuser at the login screen and see if a cog appears - change this to 'Zorin on xorg'.
