This is new: I maximised a window and the titlebar is missing I cannot un-maximise with super-f10 or with alt-up.
What can I do?
Thank you very much for your help.
What can I do?
Are you using Zorin OS Lite or Zorin OS Core?
Are you able to post a screenshot?
I am using Core, and I'd rather not post a screenshot because the app is 1Password.
However, the situation simply is, there is no title and no taskbar. It is full screen.
Usually also esc can exit from fullscreen.
Sadly, esc is not working either.
And what about Keyboard Shortcuts? You can assign one to resize the window in use.
Have you tapped the F11
key?
I thought I had tried F11, but must have missed it.
Tried alt-F11 all the time.
Thank you for that. Done.
