hey community new here and quite new to linux so please bare with me.
I successfully installed Win 10 and Zorin 18 as dual boot. Easy as cake
What I want to achieve: I need to run certain win32 software under linux and freeze the win32 libraries to protect them from updates. I would like this to happen within a second Zorin installation on the same machine which eventually would be a tripple boot system. The 2nd Zorin system would be a sort of experimental area to test different package versions without messing up other package installs.
Is this possible at all? Is there an alternative option to achieve the same goal, maybe create a user for which all kinds of tests could be made without messing up super user?
Is there any tutorlal I could use to achieve this? I couldn`t find one around here.
You could do that if You want it installed and not as VM like @swarfendor437 suggested. A VM could be good for testing but when You want it on bare Metal it would be possibe.
First, You would have to create and emptiy Partition. If You do that in Windows or Zorin wouldn't matter. I would suggest the following Way:
Create a new Boot Stick with Zorin on it if You shouldn't have it anymore. Then start it in Live Mode. Look there for GParted and open it. Shrink a Partition to get free Space for the Installation. If You should already have free Disc Space, You can of Course ignore this Step.
Then start the Installation and choose the Install Option ''Something else'' to create the Partitions manually. Take the free Disk Space and choose the Mount Point / and forat it to ext4. Under the Option ''Device for boot loader installation'' choose the Partition where the already existing EFI-Partition is.
Thank you @Ponce-De-Leon for your suggestion. Sounds easy enough. Still, what does "Live Mode" mean?
Besides, I had such nasty experiences with Win 10 in the recent days (you wouldn`t believe it ) that by now I rather want to run it within a VM, that I can simply "throw away", than giving it its own partition.
Anyway, I only need win 10 to run two programs(MT4/MT5) which have been too unstable when running under Linux with wine.
Live Mode is, when You run Zorin on the Bootstick without Installation. When the Bootstick has started and comes to the Wallpaper with the Top Bar there appear a Window with 2 Options:
Try Zorin
Install Zorin
When You choose ''Try Zorin'', it runs in Live Mode.
