Trouble opening with Zorin Menu on Dual Monitors
Hi. I'm currently facing a problem with my setup, maybe you guys can give me a help.
I have a notebook and a monitor. Physically my notebook is in my left, and my monitor is in my right side. When i plugged my monitor on my notebook, i changed the configurations on "display setings" to primary screen, but when i open the "Menu" or some app, it always opens in the notebook screen, even thougth my taskbar is on the monitor screen.
I really don't know how to resolve this.
I would suggest you to use ArcMenu instead of Zorin menu
you will have more flexibility
You also need to install Extension Manager in Software to manage it and disable Zorin menu
@Nourpon's Suggestion with ArcMenu would be worth a Try.
So, Your external Monitor is set up as Your primary Monitor, right?
What Graphics Card do You have? Does Your System run in Wayland or X11? You can check that with the Command echo $XDG_SESSION_TYPE via Terminal.
Also: Did You tried it with using different Ports on Notebook and Monitor? And how is Your Monitor connected? With a direct Connetion or with an Adapter or Hub?
Yes, my external monitor is set up as my primary monitor. I'm running wayland. I'm using HDMI conector, my notebook only has one port, so as my monitor, with no adapter. Funny that when my monitor was on my left side and my notebook was in my right side it was running perfect, but i really needed to switch sides.
So, it was like now but only on different Sides and it worked ... Hmm ... could You post a Picture of Your Display Settings?
