I used search, and found similar issues but was unable to find a clear solution. Please forgive me, if I overlooked it.
I can see it in "Disks", but I am unable to mount it. If I click the gear icon for the "volume", I only have the option to "edit mount options". (Not versed enough to change options here). There is a DVD disk in the drive, and it seems to be spinning up when the disk is inserted, and when the device is plugged in.
After some searching on the net, I tried "sudo mkdir -p /mnt/dvd
sudo mount /dev/sr0 /mnt/dvd" and got this result.
[sudo] password for pshootr: ***********
mount: /mnt/dvd: no medium found on /dev/sr0.
dmesg(1) may have more information after failed mount system call.
Below is the result of "ls /dev"
ls /dev
autofs nvme0n1p2 tty54
block nvme0n1p3 tty55
bsg nvme0n1p4 tty56
btrfs-control nvram tty57
bus port tty58
cdrom ppp tty59
char psaux tty6
console ptmx tty60
core pts tty61
cpu random tty62
cpu_dma_latency rfkill tty63
cuse rtc tty7
dbc rtc0 tty8
disk sda tty9
dma_heap sda1 ttyprintk
dri sda2 ttyS0
drm_dp_aux0 sda3 ttyS1
drm_dp_aux1 sdb ttyS10
drm_dp_aux2 sdb1 ttyS11
drm_dp_aux3 sdb2 ttyS12
drm_dp_aux4 sg0 ttyS13
ecryptfs sg1 ttyS14
fb0 sg2 ttyS15
fd shm ttyS16
full snapshot ttyS17
fuse snd ttyS18
gpiochip0 sr0 ttyS19
gpiochip1 stderr ttyS2
hidraw0 stdin ttyS20
hidraw1 stdout ttyS21
hidraw2 tpm0 ttyS22
hidraw3 tpmrm0 ttyS23
hidraw4 tty ttyS24
hidraw5 tty0 ttyS25
hidraw6 tty1 ttyS26
hidraw7 tty10 ttyS27
hidraw8 tty11 ttyS28
hpet tty12 ttyS29
hugepages tty13 ttyS3
hwrng tty14 ttyS30
i2c-0 tty15 ttyS31
i2c-1 tty16 ttyS4
i2c-10 tty17 ttyS5
i2c-11 tty18 ttyS6
i2c-12 tty19 ttyS7
i2c-13 tty2 ttyS8
i2c-14 tty20 ttyS9
i2c-15 tty21 udmabuf
i2c-16 tty22 uhid
i2c-17 tty23 uinput
i2c-2 tty24 urandom
i2c-3 tty25 usb
i2c-4 tty26 userfaultfd
i2c-5 tty27 userio
i2c-6 tty28 vcs
i2c-7 tty29 vcs1
i2c-8 tty3 vcs2
i2c-9 tty30 vcs3
initctl tty31 vcs4
input tty32 vcs5
kfd tty33 vcs6
kmsg tty34 vcsa
kvm tty35 vcsa1
log tty36 vcsa2
loop0 tty37 vcsa3
loop1 tty38 vcsa4
loop2 tty39 vcsa5
loop3 tty4 vcsa6
loop4 tty40 vcsu
loop5 tty41 vcsu1
loop6 tty42 vcsu2
loop7 tty43 vcsu3
loop-control tty44 vcsu4
mapper tty45 vcsu5
mcelog tty46 vcsu6
mem tty47 vfio
mqueue tty48 vga_arbiter
net tty49 vhci
ng0n1 tty5 vhost-net
null tty50 vhost-vsock
nvme0 tty51 zero
nvme0n1 tty52 zfs
nvme0n1p1 tty53
