Hmm this all looks normal...
The Linux Kernel is a rather basic set of drivers. It's a Large set of drivers... but basic.
Once the kernel is released by the kernel dev team, the underlying distributions must then tune and patch the kernel to their builds. Or add additional drivers. Debian, Fedora, Ubuntu... they all must patch and process the kernel, before it can properly work and be released on that distribution.
(Incidentally, this is a big part of why a user rushing off to grab the Latest Release Kernel is not a good idea. It is an incomplete product that may have regressions, missing components, etc.)
Currently, Zorin OS is up the 5.11.0-46 Kernel.
Your output shows that you are using a Higher Version than what is vetted for Zorin OS. 5.13.0-25. Which is interesting in itself, as it takes a bit of work to install a kernel higher than 5.12 on Zorin OS (Or any Ubuntu 20.04 or prior based distro) due to a bug in the packaging that Ubuntu has still not fixed.
I was thinking you may have had a Repository in your sources list that would explain the odd kernel.
But I do not see anything there.
Did you specifically install the later kernel due to your computer having New Hardware? If you rollback to booting the 5.11.0-46 kernel, does everything still work?
