Up from 16 core lite to 17 pro
I have purchased 17pro and installed it on laptop. I have 16 lite on my PC; can I do an upgrade to my paid for 17pro on the PC?
Yes, you can.
You can either do a fresh install using the .iso or you can use the Zorin Upgrader and install Zorin OS 17 Lite once it is released.
Just to clarify. If you are looking to update from 16.3 Lite to 17 Lite or 17 Pro Lite (as you have bought Pro), neither of these Lite editions have been released yet.
Once released, they should also be listed in the Zorin Upgrader tool.
Thanks: Thinking it over I'll just do a total fresh install; nothing else to do🙂.
