Upgrade/Icon Issues
I just upgraded from Zorin 15 to 16. Everything went okay, except an issue with the icons on the screen.
Where the icon should be, there is a box with the name of the app. When I click on the box, I get lines of code.
Anybody know how to fix this? Thanks.
If you haven't already, even though you just upgraded, I would to a
Then assuming that all goes well, a reboot. Sometimes even just a log out and in will fix icon issues (especially in gnome) but I just prefer the slow and steady reboot.
When you say "icons on the screen" do you mean the desktop, or also under the main menu? Can you also take a screenshot of what you see when you try to launch something?
I tried that and unfortunately it did not work.
I accidentally stumbled on to a solution. If I right click on the box then click "Allow Launching" the icon appears and I can run the app.
Thanks for everyone's help.
