Upgrading to pro error
I am trying to upgrade to pro and get an error that it cannot check requirements. below is the error. I understand I need to remove the key for runescape and all but I am not sure where to start.
[CHECKING] Started
[CHECKING:Validating Upgrade Attempt] Started
[CHECKING:Validating Upgrade Attempt] Completed
[CHECKING:Checking Filesystem] Started
[CHECKING:Checking Filesystem] Completed
[CHECKING:Creating Necessary Files] Started
[CHECKING:Creating Necessary Files] Completed
[CHECKING:Adding GPG Keys] Started
[CHECKING:Adding GPG Keys] Completed
[CHECKING:Restarting Apt] Started
[CHECKING:Restarting Apt] Completed
[CHECKING:Simulating Flatpak Transaction] Started
[CHECKING:Simulating Flatpak Transaction] Completed
[CHECKING:Processing Apt Repos] Started
[CHECKING:Processing Apt Repos] Completed
[CHECKING:Updating Apt Repos] Started
[CHECKING:Updating Apt Repos] Retrying
[CHECKING:Updating Apt Repos] Fatal Error: { error-repo-download-failed: W:https://content.runescape.com/downloads/ubuntu/dists/trusty/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details., W:Skipping acquire of configured file 'non-free/binary-i386/Packages' as repository 'https:// content.runescape/downloads/ubuntu trusty InRelease' doesn't support architecture 'i386', E:The repository 'Geza Kovacs in Launchpad ubuntu jammy Release' does not have a Release file. }
[CHECKING:Updating Apt Repos] Failed
[CHECKING] Failed
[CHECKING:Restoring System] Started
[CHECKING:Restoring System] Error: { error-repo-download-failed: W:content.runescape/downloads/ubuntu/dists/trusty/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details., W:Skipping acquire of configured file 'non-free/binary-i386/Packages' as repository 'https://content.runescape.com/downloads/ubuntu trusty InRelease' doesn't support architecture 'i386', E:The repository 'Index of /gezakovacs/ppa/ubuntu jammy Release' does not have a Release file. }
[CHECKING:Restoring System] Completed
In the Software & Updates application > Other Software tab, you should be able to Highlight and Remove the Runescape repository.
Then see if the upgrader can validate.
You show the repo as for Trusty...
That was Ubuntu 14.04... :expressionless:
Wow....I feel not very smart...I was literally on that screen to see and didn't trust my gut..Thank you so much
Hi and welcome,
When you get sorted I can recommend the installation of Stacer which allows you to turn-off repositories that are not compliant for updates. True you can uncheck in settings but Stacer offers so much more, especially it's clean up of the system function. You will funnily enough, need to disable Stacer's repo after installation.
I downloaded it, and wow this is a very useful program! Thank you for the advice!
And you may also want to download the unofficial manual for Zorin 17 Core I wrote from here:
