Hey Guys, I just installed Zorin OS 16 Core and got this error. Please help!!!
I had a similar Error yesterday cause i had to do a clean install it might be cause you Need to update your system because after i updated my system the error disappeared and didn't come back so try this ,
Open terminal
Sudo apt Update
and if there are updates
Sudo apt upgrade
or
Open software centre and see if there update from there
Worked for me Might not work for you but give it a try
Hi and welcome to the forum
Thanks for trying to help other members!
This forum is run solely by volunteers and it is nice to see the members helping each other.
Yes, I installed all the updates while installation but fortunately this error have been disappeared by now. I will let you know if this error pops up again.
Thanks for your concern.
Thanks Sir, My issue have been resolved. Thanks for your concern, I appreciate your help. And welcome to Zorin Forum. Have a nice stay .
Thanks for this update
I selected your posting as a solution.
It looks like you earned your first solution
Thank you very much...
