Hello everyone, I’ve been using Zorin OS for a short time and so far it has met all my needs. However, there is one specific setup that I used to do on Windows that I haven’t been able to get working on Zorin.
I used an A3 token-based digital certificate connected to my PC and accessed it inside a remote VM. On Windows this works automatically. On Zorin, I installed all the dependencies I could find (including from a topic here in the community), and when I access the VM via Remmina, the certificate authentication screen does appear, as if the token was recognized. However, after entering the PIN/password, the process freezes and I have to forcefully terminate it.
I know nothing about this, so I used Ubuntu 24.04 in my Brave A.I. search parameters as that is what Zorin 18 is based on and it came back with the following:
" A3 digital certificate is a type of digital identity stored on a physical hardware token—typically a USB device resembling a small pendrive. It contains a private key and digital certificate used for secure authentication, digital signatures, and encryption. Unlike A1 certificates (stored as files), A3 tokens require specific drivers and software to access their private key, ensuring higher security. Common brands include SafeNet Etoken, Watchkey, and GD Starsign.
To access an A3 digital certificate from a remote VM on Ubuntu 24.04 , follow these steps:
Ensure the VM supports USB passthrough : Configure your virtualization platform (e.g., VirtualBox, KVM/QEMU) to pass the A3 token through to the VM. For KVM, use virsh edit <vm-name> and add a USB host device passthrough.
Firefox : Go to Settings > Privacy & Security > Certificates > Security Devices > Load and point to /usr/lib/libeToken.so .
Chrome/Edge : Install via .deb (not Snap/Flatpak) and ensure the token is recognized in the browser’s certificate manager.
Note : The A3 token must be physically connected to the host machine, and USB passthrough must be enabled in the VM. Some tokens may require additional firmware or configuration for remote access.
