How to best make Zorin OS17.3 run NordLocker? I have all of the knowledge possessed by the average dummy and have read some about Wine being a product to run Windows-centric software. NordLocker states clearly that their product doesn't work with Lenux systems. I am strong on using NordLocker because of my involvement in their NordPass and NordVPN products. My workarounds so far have been via my Android phone and that is limiting my uses of a digital vault. Is there a simplest/best app to use for my needs?
Thanks in advance for taking the time to help.
Have you tryed setting up a Bottle and see it it works you have to name it then create one then point the bottle you created to the exe and see if that will get it going. only way i see it working if that fails is a web browser type
thier site says currently it does not work on linux or mac at this time but there is always the web browser
Maybe use it in the Browser? Could that be an Option for You? What I saw from these:
that seems to be available for Linux.
My apologies for my misspelling of Linux. I'm newb to my core.
I have not tried using Wine or Bottle but have been spending more time using the Brave browser to achieve my basic needs. I am learning some workarounds that are helping.
No Problem...as long as you can use it...not all apps/programs work with linux unfortunatly. i use outlook with the browser as well. Bottles is an alternative but even it sometimes fails.
