I use Zorin OS 16 with dual boot on a Win11 Laptop. When I connect a second monitor display. Zorin OS turns one display "off" and the second one "on" and vice versa. This doesn't stop. It loops between two monitors.
Thank you in advance.
Can you please post the terminal output of
sudo lshw -C video
Are you using Nvidia Graphics? If so, please try changing the driver to a different one. You can launch Software & Updates
then the Additional drivers
tab.
I am using the 525 Proprietary, as it works much better than the 535.
Thank you.
Here is the output of "sudo lshw -C video"
*-display
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 mode=1920x1080 visual=truecolor xres=1920 yres=1080
resources: iomemory:600-5ff iomemory:400-3ff irq:134 memory:6000000000-6000ffffff memory:4000000000-400fffffff ioport:3000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
I don't know what graphics the PC is using. Is thereca command to check that?
I found the cause of the problem.
I switched the power source from my laptop USB port to electrical outlet. I guess my laptop wasn't able to provide power to both monitors. Interesting.
