I installed v16 on a fresh drive, no issues other than my screen is having bad tearing/flickering. Everything I have looked up hasn't worked, my GPU is being recognized and I believe the correct drivers are installed but still having issues.
Any guidance would be greatly appreciated!
uname -a
Linux braden-zorin 5.11.0-27-generic #29~20.04.1-Ubuntu SMP Wed Aug 11 15:58:17 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
lspci -k | grep -EA3 'VGA|Display'
0a:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Hawaii PRO [Radeon R9 290/390] (rev 80)
Subsystem: Micro-Star International Co., Ltd. [MSI] Hawaii PRO [Radeon R9 290/390]
Kernel driver in use: radeon
Kernel modules: radeon, amdgpu
inxi -Faz
System:
Kernel: 5.11.0-27-generic x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/BOOT/ubuntu_ddpzbg@/vmlinuz-5.11.0-27-generic
root=ZFS=rpool/ROOT/ubuntu_ddpzbg ro quiet splash vt.handoff=1
Desktop: Gnome 3.38.4 wm: gnome-shell dm: GDM3 3.38.2.1
Distro: Zorin OS 16 base: Ubuntu 20.04 LTS Focal
Machine:
Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x
serial: UEFI [Legacy]: American Megatrends v: 5220
date: 09/12/2019
CPU:
Topology: 8-Core model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138
L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 122951
Speed: 1880 MHz min/max: 2200/3850 MHz boost: disabled Core speeds (MHz):
1: 1879 2: 1845 3: 1848 4: 2171 5: 1824 6: 1874 7: 2101 8: 1884 9: 1882
10: 1888 11: 1883 12: 1882 13: 1884 14: 1909 15: 1882 16: 1877
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: AMD Hawaii PRO [Radeon R9 290/390] vendor: Micro-Star MSI
driver: radeon v: kernel bus ID: 0a:00.0 chip ID: 1002:67b1
Display: x11 server: X.Org 1.20.11 driver: radeon compositor: gnome-shell
resolution: 1920x1080~120Hz, 1920x1080~60Hz
OpenGL: renderer: AMD HAWAII (DRM 2.50.0 5.11.0-27-generic LLVM 12.0.0)
v: 4.5 Mesa 21.0.3 direct render: Yes
Audio:
Device-1: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 0a:00.1
chip ID: 1002:aac8
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0c:00.3 chip ID: 1022:1457
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-2:2 chip ID: b58e:9e84
serial:
Device-4: SteelSeries ApS GMMK Pro type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-4.1:5
chip ID: 1038:12c4 serial:
Sound Server: ALSA v: k5.11.0-27-generic
Network:
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: e000 bus ID: 08:00.0 chip ID: 8086:1539
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac:
Drives:
Local Storage: total: 1.36 TiB used: 14.50 GiB (1.0%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
serial: rev: 2B2QGXA7 scheme: MBR
ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: rev: 3B6Q scheme: MBR
RAID:
Device-1: bpool type: zfs status: ONLINE raid: no-raid size: 1.88 GiB
free: 1.70 GiB allocated: 182.0 MiB Components: online: N/A
Device-2: rpool type: zfs status: ONLINE raid: no-raid size: 920.00 GiB
free: 905.00 GiB allocated: 15.40 GiB Components: online: N/A
Partition:
ID-1: / raw size: N/A size: 880.43 GiB used: 4.54 GiB (0.5%) fs: zfs
raid: rpool/ROOT/ubuntu_ddpzbg
ID-2: /boot raw size: N/A size: 1.67 GiB used: 97.4 MiB (5.7%) fs: zfs
raid: bpool/BOOT/ubuntu_ddpzbg
ID-3: /var/log raw size: N/A size: 875.90 GiB used: 7.2 MiB (0.0%) fs: zfs
raid: rpool/ROOT/ubuntu_ddpzbg/var/log
ID-4: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap
swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/nvme0n1p5
Sensors:
System Temperatures: cpu: 39.8 C mobo: N/A gpu: radeon temp: 59 C
Fan Speeds (RPM): N/A
Info:
Processes: 599 Uptime: N/A Memory: 31.36 GiB used: 2.69 GiB (8.6%)
Init: systemd v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Shell: bash
v: 5.0.17 running in: gnome-terminal inxi: 3.0.38
Also feel I should mention that every once in a while everything freezes, apart from the mouse cursor, and I am forced to restart my machine.
